Re: I NEED HELP WITH THE WIRING CONFIGUATION UNDER THE FLYWHEEL IT IS A 69
sorry about that, it is a 55hp chrysler a 1969 i think. it has a point style system with no condensors and it is a magnedo(doesn't run off battery) i think that it what it is called. it is also a two cylinder. right now there is three wires. two of them go to cd modules wires. i think that they are both power leads. the third one is connected from the stem that the other wires are connected to and then it scews down to the power head i think.( the peice that is the bottom of underneath the flywheel. i am not sure what the third wire is exactly. maybe it could be a ground or maybe it is keeping the maganet plate from jumping arc. is this right
