I need help with 84' evinrude
MINTER357
I recently bought a 84 21' Dusky center console with a 200 HP evinrude. The engine starts and runs fine. My problem is when I am in the water I can not get the bought to go over 8 MPH. Every once in awhile the RPMS will increase and before I know it it is planed out and going 50 MPH. It will only stay at top speed for about 5 minutes till it goes back down to 8 MPH. The engine sounds good and does not sound like it is missing. Any help would be awesome.
kenmyfam
Re: I need help with 84' evinrude
Could be power packs. Just a thought. Had an old 60hp that did the same thing.
airframer
check your fuel lines and pump
MINTER357
Thanks for advice. The power packs were replaced last year, which I guess doesnt really mean theyre good. I did notice that the hand primer bulb does not really get very hard even after it is running. But I have never had a problem starting it.
kenmyfam
How about a compression and spark check.
Primer bulb is just that. Just a fuel line after it is primed.
MINTER357
I did pull three of the spark plugs and noticed they were wet from un burned gas
airframer
could be intermitten spark. i would check that
Konvicted
Im far from a boat mechanic but a friend bought a boat a few weeks ago and was doing the same thing. The connection on the gas tank was stripped and taking in alot of air and keeping it from running much at all. Also the primar bulb wouldnt get hard or take hardly any gas in at all.
So could possibly be the fuel line sucking in air some where.
TimmyC
sounds like it maybe the power pack, I have had a problem like that and I am going to change the power pack tomorrow. I ll let you know what happens.
