JonDick13926
- Aug 18, 2013
- 14
I have a 1976 Dolphin something (according to the title and the "dolphin" plate on the boat). The engine is a 1979 115 hp mercury (6 cyl 2 stroke carb). The throttle control (mercontrol - exactly like the one pictured) has a key ignition in it. The boat also has a key ignition that I'm assuming was for whatever engine was initially on the boat in '76. It's not wired up. The engine harness carries the wires from the throttle control to the engine and based on the wiring diagram I found most of those wires are for the key ignition and I guess a portion is for the tach (not sure how that works). The wires on the internal wiring harness are horrible. I guess they've coroded over the years and others has spliced new wires in there and they've corroded too and now I've got a horrible internal wiring harness that would cost me $160 to replace. I'm wondering if it's possible to just wire up the other key ignition instead. Here's how the independent ignition is set up:
It has six terminals on the back:
M -
M -
I - Engine Ignition??
B - Positive Battery Terminal
C - Choke
S - Starter Solonoid
The problem I'm having is, I know one of the "M"s is for the ground and one is for the kill switch. Neither is raised and they look identical so I don't know which is which and even if I did I don't know where the kill switch wire is supposed to go.
The second problem is that I don't know where the "I - Engine Ignition" wire goes.
Can someone help? I also posted a pic of the wiring diagram for my engine.
Edit to add: I forgot to mention, the reason I'm doing this is because the engine wont start. It wont do anything. The starter doesn't even click, let alone turn the flywheel. I'm 99.9% sure it's because of the now solid GREEN wires coming from the internal harness.
M -
M -
C - Choke
