i need help w/ naming a missing piece!?
Colinw
i am missing a piece that connects my throttle to me engine, it is a 1969 merc 100hp w/ mercontrol. when i push the throttle down you can see it move and the piece under it isnt connected. you can manually move the piece underneath to get the engine going faster. when i took it out it went about 7mph full throttle.. any advice would be great.
Colinw
Re: i need help w/ naming a missing piece!?
see image i dont know what its missing?
4Bassin
What you are pointing to is the shift shaft. I doesn't have anything to do with the throttle. Moving that arm will select either forward or reverse.
Moody Blue
Triplicate post. How many times do you need to ask the same question?
http://forums.iboats.com/showthread.php?t=274187
http://forums.iboats.com/showthread.php?t=274264
http://forums.iboats.com/showthread.php?t=274215
Please be patient when waiting for a reply. It may take a day or two in some cases before someone comes along to answer your question. If still no reply, just "bump" your original post back to the top of the list by replying to your own post. Eventually you will get a reply.
Let us know how the testing went, but pick one post and continue on with it. Its VERY confusing to follow multiple postings on the same topic.
