BradJFelix
- Jul 31, 2007
- 11
Hey guys I need some help. I have a 77 Evinrude 70hp. I recently purchased it and I am trying to get it running. The guy I bought it from had all the carbs rebuilt last year and it ran last summer I saw the $500.00 receipt. I can't get it to start. I can get it to run when I spray fuel into the carbs but not on its own. I pulled the main line off to the center carb where the fuel comes and pumped the primer ball and I had fuel there. When I pump the ball it pumps up tight and I see no fuel coming from the carbs thinking maybe the needle in the float area was stuck open.
I can't imagine that all 3 of those needles would be stuck closed especially after it being worked on last year. My battery is good and it obviously has spark or it would not run when I sprayed the fuel straight into the carbs. I messed around with the kill switch thinking that was it but then realized that if I can get it to run when I spray the fuel in that it would not be an issue with that. Does anyone have any direction to send me in. Thanks a lot in advance I appreciate it.
Brad
Brad
