Re: I need an engine block
If you are going to do a rebuild it is a must to balance the whole motor. You will not be sorry. A 100.00 to 150.00 bucks will extend the life of your motor by more then 25%. Cant beat that. Also think about all the upgrades cam,timing chain,oil pump before you start. Myself I would do a master rebuild kit (cam,lifters,piston heads,oil pump,time chain ect and all gaskets for around 200.00 from Northern. Most important though is balancing the motor. One last thing. Take pictures of you motor before you take it apart. It makes it real easy to figure out how that bracket goes back on.
