I need a wireing diagram for my ignition switch
Status
Not open for further replies.
ezeke
Re: I need a wireing diagram for my ignition switch
There are many different wiring diagrams. We will need to know the model and year, and also the model number if possible.
boat boy
thank you for a fast reply ,it is a 1998 johnson 150 the switch has 6 little prongs with the letters A,S,M,B,C,M
Silvertip
This should help. Wire colors are for Mercury but the terminals are the same.
boat boy
ok thank you i will try that but i do have two purple wires
boat boy
That is a great diagram only if i had one for a johnson 150 and if there is any type of fuse that could have blown because i am getting nothing
ezeke
Engine fuses are on the engine. Look near the starter solenoid.
Heres another view of the control wiring:
boat boy
ok thank you i will go look but i need the diagram for the igntion switch with push to choke like the one silvertip gave me but for a johnson 150 the name of the switch is pollak with 6 prongs one is in the center
ezeke
It does not matter how the connectors are arranged. All of the 6 post ignition switches for BRP/OMC motors are push to choke since 1979. "C" is always choke.
boat boy
Ok thank you!!!! thank you!!!!!
I got figured out i got it to turn over again and found the blown fuse. You see i was using my boat all day yesterday until i was waiting for a big tug to pass with it in neutal then when i put it in gear it killed now it will not start thats how why i started to try to check my switch do you have any idea why? i did take out a plug and turned it over to see if it is getting fire but it does not seem to be any input would be great. You all have already helped me so much
You folks have been a great help as I restore a 1988 Javelin with Johnson 150 V-6. And I need help again.
Having to replace the iginition switch with choke.
The old wiring poles are labeled: M,B,M,A,C,S
The new switch poles are labeled: M,B,M,I,C,S
So the question becomes are A and I poles the same?
Please hurry as I am ready to rewire today.
Thanks again to all.
garzilla
I'd say you're fine.....maybe the new switch calls it "ignition" instead of "accessory"....
hanzecrypt5300
I have a Evunrude 50573B and also am having a little trouble with wireing my new ignition switch. The diagram here looks differant to my switch. Please help. Don't want to blow up my boat.
wilde1j
This is a 2007 thread. You guys should start your own thread.
hanzecrypt5300
Not to sound stupid but I'm new here. How do I start a new thread? My question still stands only now there are more questions. I'm also having troubles with my throttle and am looking for a diagram. The moter is a evinrude 50573b.
kenjou
Where can I buy this Ignition Switch with six terminal for my Evinrude 235hp?
JB
Threads found by search are for reference only. Please do not reply to them or hijack them with your new question.
There is an icon when you have the forum page that is in the same place as the "reply" icon you clicked to do this. Use that to start a new thread.
Status
