Re: -i know i might catch heck about OMC
Disconnect the large red cannon plug. Jump the solenoid to check spark. Be careful if you try to start the motor -- with the cannon plug undone you will have no way to shut it off. Use this method to verify spark on your spark checker only.<br /><br />If you now have spark, there is a problem in your kill ciccuit from the plug forward. If you still have no spark, the problem is from the plug back.
