i have a 74 merc 85hp. no gas
xengrns
1974 merc cleaned fuel pump new lines,cleaned carbs no suction at carb how do you clean reed valves
gm280
xengrns, I don't understand the "no suction as carbs" statement. You should have a fuel pump that supplies fuel to the carbs. The carbs don't pull gas to them, the fuel pump pushes gas to the carbs. So if you are not getting fuel to the carbs, time to check your fuel pump and the entire fuel delivery lines and system from the tank on. . JMHO
Chris1956
The reed valves in that motor are very robust. They would cause a rough idle. I would put them on the bottom of the list for issue.
Check compression and spark​. Clean carbs next.
