I have a 1971 Thunderbird bowrider and I'm scared!
scootyfish
This boat was given to me by a friend. It needs: a motor, new gages, new seats, a fold back center windshield, and a gas tank. The floor is rotted and the fiberglass @ the base of the windshield and on the right side of the rear deck was repaired but, looks really bad. Considering all this should I take all this on as a restoration project? I have no prior experience. Pls help, thanx.
rickdb1boat
Re: I have a 1971 Thunderbird bowrider and I'm scared!
Hi scootyfish <br />I would say that you should pass on this one. You will spend lots of bucks on the motor and rot repair alone. Plus, having no prior experience at fiberglass repairs, you could be in for a nightmare. Try to find something that is in decent shape to begin with and then go from there. Something that needs cosmetic repairs(Buffing, Seats, Carpet, Ect) can be had pretty cheap if you look around. If it has a solid hull and running motor with good compression, you are half way there!!
steelespike
A rotten floor can also lead to a weak bottom<br /> Sight along the bottom,should be uniform with no hooks or bulges.Wouldnt hurt to push on the bottom here and there.Take hold of the transom<br /> and push front to back if it flexes it will need a rebuild.If you find problems I wouldnt reccommend it for a beginner project.
JasonJ
I am in the middle of a project like yours. I have a 1970 17 foot tri-hull that I am converting to a center console fishing boat. My motor runs great, but I have to replace transom, floor, stringers, basically anything wood. I then have to modify the upper deck by removing both consoles and reglassing everything for structure. This sort of project is not for the faint of heart, but it won't cost "thousands" either, unless you take the weak way out and pay someone else to do it. That being said, if you do not think you are up to the task, by learning how to do the necessary work, then you should pass on this project. I am doing my project because that is what I like to do. For me, the project is more fun than the end result. If you just want a boat to do stuff with, you should save your cash and find one that is decent and only needs superficial work. One strong benefit of rebuilding the boat is you know for sure its condition, but if you do it wrong, it could be unsafe. Good luck either way...
miloman
I agree with the other guys unless you are prepared to do a lot of reading asking questions etc.. you are in for more work then you could imagine. Now that being said, if you are prepared to spend endless hours in the garage, and taking it slow go for it if not I agree with the others. FInd a project boat that really reqires cosmetic work and start there
rickdb1boat
Edit: Never Mind
scootyfish
Well guys, my decision has just been made easy for me. My wife saw this posting and said " I'm suprised you feel that way because everything you put your mind to you do well". With a vote of confidence like that how could I not give it a shot! I'm going to need your help though fellas. Thanx for the replys keep em comin'.
boatingfool
Know your limitations before you leap.
snapperbait
Scootyfish... If you've got your heart set on the project, let me suggest that before you start tearing into it, you find some books on fiberglass repairs, painting, electrical, and a service manual for whatever motor you choose.. There are many very informative books out there that will cover just about any repairs you may need to make to make the boat seaworthy..<br /><br />A few things to remember tho, and I don't mean to make it sound bad, BUT..<br /> It's going to cost 4 times what you think and take at least twice as long as you think to repair it.. ;)
Rick Byers
Scootyfish e-mail me and I will give you the # for the best glass man in Virginia. He is my younger brother. <br />rbyers3963@aol.com<br />Rick
JasonJ
Go to Project Boats and look for any posts with my name or refering to "project Skanky Beast", I have posted pics of my progress. I am on the verge of beginning the reconstructing of the boat, the temps are finally warm enough during the day. I have all the resins and wood and floatation foam and all that. I have spent close to $600 so far on materials. I have a budget goal of $1200 to $1500, and I should meet that goal easily. I still have paint and electrical to buy, as well as miscellaneaous doo-dads. Definatly get some reading material on the subject. Runabout Renovation by Jim Anderson is a decent basic book, it is easy to understand and tells you how to rebuild a crusty old boat. Good luck, and post pics of the progress....
