I can't reply to posts.
GA_Boater
Which forum, Tyme? The link is to the Main Forum and no, you can't reply there.
WIMUSKY
When submitting your post do you get an error? After you get an error do you refresh your page so the post goes thru? You may want to copy your post in case it gets lost. Sometimes a post has to be submitted twice. Another way to reclaim your post is to hit "restore" above the text box, most if not all of your post should be recovered..... Then you can resubmit it...
GA_Boater
I don't see any recent new replies or started topics except this topic, Tyme. It looks like you started this topic in Dockside and was moved here to Issues.
I've been seeing two errors when making replies or starting topics. The first is the Database error after hitting the Post button, clicking OK then refreshing the page has displayed the new reply or topic. The second error is an Edit error that pops up while I'm writing the message. So far after clicking the OK for the Edit error and continuing to write the message, clicking Post when finished has popped up the Database error. Clicking OK and refresh does not display the new reply or topic. I've used Restore above the message box and re-posted.
Did you get a Database error after clicking Post or an Edit error while you were writing the message?
Bob_VT
There has been an identified glitch and sometimes the reply box does not show up. It is not you and it happens to many people myself included. Once we ride out this software storm everything will be okay.
