carguy5068
- Oct 30, 2011
- 21
I have a gorgeous 19ft 79 cobalt boat that has been pampered all its life. never seen weather. I bought it from origional owner who rebuilt the impeller and bearings at the end of last season. since the rebuild the boat quit shifting smoothly now not shifting at all. origional owner claims that he had outdrive supported on cherry picker and either release valve wasnt tight or his kid messed with it. regardless the unit hung on shift cable. I purchased a used cable assembly and was just wondering if it could be something else causing problem. havent recieved too much good news about the hydromechanical shift but others have said they work good when properly adjusted. boat starts, runs and sounds awesome but when i try shifting foreward or reverse i get a growling sound like not totally engaging. guess my question is do you think the cable is the problem or do you think the owner messed something else up replacing impeller? also what am i looking at cost wise to have professional replace cable? thanks in advance mark...
