Re: hydrolocking question
Dunaruna, you are 100% right.<br />That is exactly what i did, removed a plug on manifold thinking it was a water port, but nooo it was not ,intake. After relializing what i had just done,sucked as much ant-freeze out as i could. without knowing anything about hydrolock, tryed to start engine.a couple turns of the starter and whack, instant stop!<br />So at this point, removed plugs,blew the water out of cylinders,dryed plugs and started. I then let it warm to normal temp. Shut off and started changing oil,3 times to be exact to flush milky oil. Oil did clean up nice. On last start-up I fogged engine,(marvels) did the winterize thing minus the water in intake. Put boat to bed... But now im sitting here wondering if this sping will this boat run at high rpms and what damge my have occurred?<br />This was my first time winterizing and new to boat ownership. Am looking for a manaul for this vessel,but that doesnt help at this point.<br />oil pressure normal, temp normal, running on muffs,engine sounded normal......<br />2005 bayliner175 with 3.0L merc<br />should had takin it in, but live and learn i guess
