1961glastron
- May 8, 2010
- 24
i'm having issues with this reverse on my hydroelectric shift johnson,,,i know theres alot of info on here covering it already but not really helping out much,,i already tested the switch in the control box(all good)i checked the 2 wires going to the lower(all good as stated in the other posting)I noticed today that forward works good ,,nuetral works good,,but when on the hose reverse works but when throttled up alittle it kicked out till throttled bad down,,,when in the water i get nothing in reverse,,i'm gonna do the jumper wire test in a minute and see if that helps but i dont think i should use the hose but to use a barrel instead cause of the pressure of water,,i can here the sylonoids working,,yeah i'm runiing type c unit oil also,should i drop the lower and look around some if the jumper dont helpdo the sylonoids ever stick or the pump get gummed up cause the las owner put hi-vis lube in it right before i bought it please help me out,but i switched it all out to type c
