Re: Hydro Lock - Volvo Penta 4.3L 190 hp on 2003 Stingray 190LX
DHP writes
My feeling is your dealer should be handling this for you. If he cannot satisfy you (not so far at least ),he should be able to have you meet a Volvo service rep at his dealership,and with the boat.I doubt Stingray improperly designed your boat,But that should be able to happen also.
Jeffmc writes:
must be a common problem was running my wellcraft excalibur with muffs on in the yard also had the 4.3 volvo motor. it ran fine trailered it to the landing got it in the water went to start it and what a noise it was locked brought it back home pulled the plugs drained water put a new seperator on it ran fine after that
Both those are bold statements from those that have no affliliation with Volvo.
DHP.
Agreed, the dealer SHOULD handle this. Trouble is, marine dealers will not and do not do so. That's an
industry PROBLEM! Only dealers can fix it. I only deal with dealers that will back me up. Trust me, they are few, and far between.
Jeffmc,
Yes, you backed the boat in at it's
worst angle for engine flooding. And, did you overpressure a cooling system using a garden hose? You can. I've seen city water pressures as high as 140 psi.
As stated, I'm not ready to blame Volvo for anything. Unless, as stated, there was an obvious gasket/seal failure.
Nobody reads operating manuals anymore. We choose to waste our time on lawyers and finger pointing.
Sometimes, the fingers point to the operator. But, nobody believes it. Thus, a litigious society.
I hope this customer gets this worked out. I'll bet Volvo, will help, if the case is presented correctly. But, make no mind, that this is, by any means, a warranty issue.
This issue, at this point, is all "goodwill" on Volvos part, should they decide to participate.
I make these decisions everyday. Lack of knowledge is one case, blatant disregard is another.
I'll side on the case of the prior, everytime.
For you Spike. Approach Volvo carefully with facts, in hand. Approach respectively.
If you go in with "guns blazing" you'll get-ZERO! Respect and coutesy begets respect and coutesy, in kind. Remember, the people you talk to are people too.
Good fortune to you.
Let us know.
