battery reads 12.20 my shift wires read 9.55 volts is this enough power? 69 johnson 55 hp help
T transamjegs Cadet Joined Sep 3, 2010 Messages 24 Sep 8, 2010 #1 battery reads 12.20 my shift wires read 9.55 volts is this enough power? 69 johnson 55 hp help
D Daviet Fleet Admiral Joined Sep 24, 2008 Messages 8,958 Sep 8, 2010 #2 Re: hydro eletric shift You might loose some voltage through dirty or poor connections. The voltage should go up with the engine running. Are you having a shift problem?
JB Honorary Moderator Emeritus Joined Mar 25, 2001 Messages 45,907 Sep 8, 2010 #3 Re: hydro eletric shift You need to reply to your original post, not start a new one in the middle of a conversation.
