hydro-electric shift probems
M Kenyon
i have a 50hp johnson with the electic shift and like others i have a problem with it. I have replaced the switch in the control box once and the new one i put in is know bad also the plastic just seems to go bad causing the switch not operate. I would like to wire a remote switch on the boat so i can eliminate the one in the control panel(a new is 80$) but i need wiring schematics to do this. thanks
Hooty
Re: hydro-electric shift probems
Schematic should be in your manual.<br /><br />c/6<br /><br />Hooty
Joe Reeves
M Kenyon.... There's really no need for a wiring diagram. For the Hydro Electric Shift unit, the applied voltage is as follows:<br /><br />Neutral = 12 volts applied to the "Green" wire.<br /><br />Reverse = 12 volts applied to both the "Green" and the "Blue" wire.<br /><br />Forward = No voltage applied.
Dennyps
Hey M. Kenyon, Just a piece of advice go to the green and blue wires in the motor compartment and try this. disconnect the knife connectors and run a 12 volt jump line {preferably from the boat battery=positive side} first to the green and then to the green & blue {while running motor on muffs or in a tank} and make sure that your lower leg is actually shifting as well then you can be absolutely sure that your LU is working properly. Hope this helps, Denny
