The ram's have been extended for 4+years, with plastic covers on them, and also taking the weight of the out drive off the ram's themselves.
The throttle has two buttons on it, I assumed top was for 'up' and bottom for 'down'. However, the top button does nothing. No noise, no click, no anything to the hydraulic motor in the back of the boat. Completely dead. The bottom button makes the motor kick in which sounds normal. At first I though this might be the problem, that only 'down' is working and I need to figure out why the raise button isn't functioning.....but when looking at the dash there is a 'Outboard Tilt' switch. Up/Off/Down?
Am I missing something? Do you use the two buttons on the throttle to go up/down, or do you just use the bottom button and choose whether to go up/down with the switch on the console?
http://jmorgan.me/boat/tilt.jpg
http://jmorgan.me/boat/throttle.jpg
You can lift the out drive up/down by yourself, without lifting it falls completely down. The pump is kicking on though when pressing the down button. I took the screw off the top of the reservoir and see oil inside. I think the first step is to bleed the system, to see if it's just air causing the problem.
So if the top/bottom button the throttle is for trim what is the switch on the dash for? And if the switch on the dash is used in conjunction with the bottom button on the throttle what is the top for?
Also.. if the out drive is completely lowered with a working out drive hydraulic system, can you pick the drive up and lift/extend the rams by hand? or when lowered is there pressure to keep the rams from extending? Basically trying to figure out if there is any significance to the fact I can lift the out drive up/down by hand right now, or if it would behave that way on a 'working' systems that was completely lowered.
