Hydraulic Trim on 1991 Evinrude 150 HP
haxsaw
Can the trim on this motor be rebuilt or am I better off replacing it with whole thing.. it is acting like the seals in the cylinder are leaking by, you raise the motor and it slowly lowers by itself..
Mumblerone
Re: Hydraulic Trim on 1991 Evinrude 150 HP
I would look for a good shop to check it out...they can be rebuilt. A new one is well over $1500.00. Probably jus a seal. Have you tried adding more fluid? :(
dgates
Hello Mumblerone,<br />You sound like someone who is experienced with Johnson Tilt/trim problems. I have an 1986 115 Johnson V4 where neither the trim or tilt will<br />go out (up). Motor runs ok in both directions, but motor and pump just whines when I try to go up. Fluid level is ok. Can you help narrow the problem?<br />Thanks.
Mumblerone
dgates...be glad to help if I could. My experiece is limited to the problems , I've had over the years. Not sure about yours. This is a great site and I'm sure someone will get back to you. If not in a timely manner...repost. Have a good day. :(
