Re: Hydraulic Trim Motor
Rhadley, I've cleaned all other connections, starter motor works, relays work correctly when power was jumped (I used my jumper cables)to the relays directly from battery, trim switches worked correctly, it just wouldn't work off of the existing hot lead which is attached to the starter motor. I didn't think to unconnect it and place it on the battery for a test. I'll try that next. Thanks for the ideas.
