Re: HVLP Painter?
Gota go with Chief! I own several HLVP's one with it's own turbine - like the one pictured; except it will run multiple guns. Four that use compressor air and reduces it at the gun. I spray lacquer with these. I would run them off pots if doing large runs. Now I just use them for small runs and with a cup: as I bought an Airless unit; pro model. <br /><br />Go with the Airless if doing large areas, especially latex. I find the HLVP is best with thinner paints - have to adjust the flow rate. Most Airless will draw from the bucket or can.<br /><br />PLUS; you can rent a Airless and it will do the job in half the time. All the house painters and high production sprayers I know use Airless -- there is a reason.
