Just installed this with a transom mounted transducer. It's rock solid at anything above 10-15mph, but any slower than that, including when not in motion, it looses depth readings randomly. I find this odd as it's usually the other way around.
I have the transducer mounted next to the starboard side Smart Tab, which I thought might be problematic, but I was trying to keep it the recommended distance away from the prop and clear of under hull strakes.
My theory is that at higher speed, the Smart Tabs lift up enough to not cause trubulence at the transducer, but when I slow down, they retract back down and the do cause turbulence...however, that does not explain the random and frequent reading losses while not in motion. At that point, the transducer is fully submerged and there is zero turbulence of any kind.
Thoughts?
Thoughts?
