Hub v/s Spindle
Steelmonkey
So, since the weather is bad here in the northwest, I thought I'd work on my EZ Loader Trailer. I purchased 2 Replacement preassembled hubs from West Marine. Since I've never done trailer work before, I watched a couple of videoes on youtube and thought I had it down pat. Armed with my Hub replacement kits and enough grease to grease all the neighbor's trailers, I removed the old hub, severely rusted and pitted and actually had difficulty removing the bolts.
I greased the new set and mounted it on the spindle....only to find out my spindle isn't long enough....??????
The new hubs appear to be around 1/2" longer....does anyone know what I can do now? Looking on the internet that's suppose to be standard....any ideas?
jusfloatin
Re: Hub v/s Spindle
Your hub assembly is probably set for a 1" spindle and you have 1 1/16" spindle.
Look at the numbers on the fat side of the bearings are they the same.
Steelmonkey
Re: Hub v/s Spindle
No the bearings are identical...it's the actual physical width of the inner race. If I lay both hubs side to side, the difference is considerable.
CATransplant
Re: Hub v/s Spindle
Some older EZ-Loaders had short spindles. I had one of them. Hubs are available, but hard to find, for those. I got mine from one of the trailer superstores, but really had to hunt for a long time.
There's no option, unless you want to change axles. The shorter spindles are 1/2" less deep than the standard ones. Bearings are the same.
Try here:
http://trailerpartsdepot.com/itemdesc.asp?ic=0014&eq=&Tp=
Steelmonkey
Re: Hub v/s Spindle
CATrasplant you are my new hero! That is exactly it!
Thank you so much for your time and wisdom!
Stachi
Re: Hub v/s Spindle
check out the hub installation link at the bottom of that page.
