In the Yamaha Service Manual it says to check fuel pressure at the VST within 5 seconds after start switch is turned on and that the pressure should be 50.8 psi. After 5 seconds the pressure should be 43.5 psi. Then after warming up the engine the pressure while running should be 50.8.
On my engine the pressure within 5 seconds is 100 psi. After 5 seconds the pressure drops down to zero. While running the pressure is upwards of 100 psi.
My questions. Should the pressure regulators be operating within 5 seconds to keep the pressure down to the 50.8 specified? Then how long should it hold the specified 43.5 psi before leaking down?
The manual also says to test the regulators by applying vacuum to the pressure regulators and that at the specified level fuel pressure reduces.
What is the "specified vacuum level"? I can't find it anywhere in the manual.
I apologize for the wordy post but hope that I got my point out there. This has been an incredibly frustrating couple of weeks...
