Can not find plate on a 1985 Polar Kraft 28 foot toon--currently has a 85 Force and looking to up grade to a 115 Honda . Cant find any info on this boat as the company has gone away Thanks for any help guys
There is a Coast Guard formula for figuring out MAX hp on a pontoon. You need to figure out your Cubic Feet of flotation first, then multiply by length of the toons, then divide by the diameter of the toons. Personally I haven't seen a 25'+ pontoon that hasn't been rated for at least a 115hp.
Just a quick calculation with 23" log is showing ~170hp for a 28' toon, but its more that likely limited by the strength of the Transom pod and please note that the 480# Honda 115 is going to be a lot of weight on a transom designed for a 330# 115hp from 1985 and WILL need some reinforcements. Trust me, my 360# 70hp Johnsuki bent the transom of my 70hp rated old pontoon the first summer I owned it! the "OLD SCHOOL" 70hp engines were in the 220-250# range.
The Force is 249 lbs, a 2000 115 honda is at least 496,a 2000 Evinrude is at least 349.
Just assuming your doing used. If your thinking new the Honda is still around 490, the Evinrude Etec is about 405.
I mention the Etec because it is a direct injected 2 stroke that meets all CARB requirements.
