How would you check it out before you buy?
mtns1234
Going to look at 2 10hp Sportwins today. What should I look for before I buy?
Regards:facepalm:
lindy46
Re: How would you check it out before you buy?
Check compression and drain a little oil from the lower unit. If compression is good, most other problems can be fixed. If the oil is milky, or if water comes out, then you know you will be replacing some seals, which is not that difficult a job. You could also check for spark on both plugs to see if it needs ignition work. If you're in a warm climate and you can see the motors run, that would be the ultimate test.
kbait
If he's selling them as runners, bring a stand and a plastic barrel to confirm. If not, as above, compression, spark, lower unit contents..
kfa4303
Banned
Well the three main things you want to check for are compression, spark, and fuel. That being said any or all of these may be on the fritz when you check out the motor, but can ususally be fixed with realtive ease depending on the make/model of the motor. Ironically, the newer the motor, the more expnesive and therefore less worth while it would probably be to fix. However, if they're between '55 and '74, or so, you're in luck. OMC motors from that era are cheap and easy to fix.
If they can start the motor(s) in front of you and run them in a TEST TANK (not muffs) that would be ideal. That way you could see it start, idle and shift into/out of gear and perhaps most importantly that it pumps water to cool the engine. If they motors are not running, no need to wory there are lots of things you can still check. Try spinning the flywheel CLOCKWISE (only) by hand, or with the pullstarter, for a crude test of compression. You should feel a tight sort of "lub-dub" action. If you do the compression is probably ok. Of course it would be best to take a compression gauge with you to see that the cylinders are within 10% of eachother, but that may not be possible. Even if the compression is a bit weak there are some easy treatments/tricks you can do to improve it if need be.
To test the fuel system, try pumping the bulb on the fuel line until it becomes firm. Let it sit for a few minutes and check it again. If it's still stiff, the fuel system probably doesn't have any major leaks.
You can do another rather crude test for spark by removing the spark plugs and reattaching them to the spark plug wires. you can then ground the plugs on the engine block and pull the starter a few times. you should get a snapping white/blue spark. again this is only a crude test, but it can yield some basic info.
These are only crude tests that you can do quickly while checking out a motor, but the're a good starting pont. You should resign yourself to spending an extra $100-150 on top of the price of the motor to get it into tip top shape. These motors can/do have several "consumable" parts which can/should be replaced regularly. Don't count on the previous owner having done so. These parts include a carb kit, impeller (Waterpump), tune up kit (points and condensers), spark plugs and spark plug wires. They're all easey to reinstall and you can buy them here at iboats. There are tons of tips, directions and pointers on how to install them all, right here. Hope that helps some. Keep us posted. Pics are nice. Good luck.
stewfish1818
Cheap $39 compression tool at autozone and return after use or keep for future checks and for friends.
Remember 1989 & 1990 had lower compression like around 90-100 could be other years but that's what I know.
Look for uneven wear/ compression in each one.
Has to go in the water
mtns1234
Great advice thanks all. This is the story from owner, one motor ran, about a year ago, but ran poorly at idle. He was told the reeds were out of adjustment. Second motor is for parts.
jbjennings
They should be purchased as BOTH parts motors as far as price, unless they can be shown to run. Reeds can't really be out of adjustment as far as I know. Reeds either fully close or don't work. Bad compression usually manifests itself at idle first. But, compression can be checked.
Seems like every piece of junk I've ever purchased "ran a year ago". :(
