How to use seafoam?
Newbie@boats
I would like to run Seafoam in my Force125.
How can I run it? Do I just hook it up to the fuel line and let it suck through...
Or would I be better off putting it in the gas tank?
notsunkyet
Re: How to use seafoam?
NO! PUT IT IN THE FUEL TANK! if ya try to have the engine suck it up itll mess up more than help.. what i do, if the motor is really gummed up, is put like half a can of it to a gallon or two of fuel. also i like "DEEP CREEP" pull the plugs and spray heavily in there and let it sit for a day or so. and itll smoke like all get out for a bit when ya start it. its ok let it clear out and itll be fine
Xelaw
I take the intake off, start the motor, and spray a little in all of the carbs until it bogs down a little. I repeat this like 3 times then spray more in each until it stalls out. I let it sit for about 10 minutes, then start it up and run at high idle until it stops giving off white exhaust.
findinghomer
are you sure? i bypassed my fuel tank and filled a small fuel jug with a full can of seafoam, and just little gas/oil, let it suck right through the whole system. runs at idle speed now, when it wouldnt before. i sure hope your wrong :confused:
notsunkyet
no thats fine a small jug of fuel and seafoam is perfect... i had a freind of mine try and force pure foan in the fuel line .... it didnt really hurt anything but waqs a huge mess... let it run for about 5 minutes and shut it down and redo a few times youll be fine
findinghomer
ohhh ok. scared me for a minute there :) only had it out once since then, and it seems to have really helped.
