How to Tune Up Evinrude, Super 6.5 HP
Status
Not open for further replies.
cumana
Hello Forum this is Francisco Gomez from Cumana, Venezuela, This is my first time in this Forum, Recently I purchased a Evinrude Super 6.5 HP, but unfortunately I do not know how to tune up the engine and the ideal oil -gasoline mixture, I was locking for a web side link or something where I could get this information but I can not found it. Please could you let me know where I can get tune Up and Mixture information for a Evinrude , Super 6.5 HP, I will appreciated so much you help in this matter
jimmbo
I have went through the Evinrude Brochures from 1920 thru 1955. Nowhere did I see a 6.5 HP, let alone a Super 6.5. Granted these were for the North American market. I don't know what OMC was offering in foreign countries
Really oil usually means 16:1 gas oil. Maybe even more oil like 10:1. TCW-3 oil.
hardwater fisherman
If it is something like this than it was made in the 1980s or 1990s. And would probably use 50:1 fuel mixture.
cumana
Hello Hardwater, a pleased to contact you, thanks a lot for your answer and photo, yes the Out board on your Photo is the same that I asking on the Forum, please if you know where I can get the related information I will appreciated so much
cumana
Hello Jimmbo, nice to meet you, thanks a lot for your answer, and as you can see on the hardwater photo, this is the Evinrude that I asking to tune up and ideal Oil mixture, may be is was a especial Edition Outboard, really it was a precent from a friend, it was in a very good maintenance and according to him it has around 15 years with out start, now I can run the engine, but due to bad mixture Oil it has to much smoke and i can not hold idle rpm, in slow aceleraion.
Please if some body of the forum can help me to tune up I will apreciated so much
cumana
Hello Forum how are you, regarding to tune up Evinrude, Super 6.5 HP, I found a web site where shown General information about some topics of this Outboard, mainly Carburetor adjustment. http://www.leeroysramblings.com/OMC_6hp.htm
Base on it I could observe that in my case this carburator do not has idle needle jet Knob, of course I can adjust with screwdriver, but when the engine run it move due to do not has knob and components to asure to do not move with engine vibration.
Please somebody know where I can buy a Envinrude 6.5 HP Carburetor repair kit, included Idle nedle jet screw and knob, it must to be a web site because I am very far from USA, but I have a Mail boxes address in Florida, no problem to received it.
Thanks a lot for your paciense and time in this item
cumana
Parts Help Needed
Hello Forum how are you, I am a new member on this great forum, recently I get a EVINRUDE , Super 6.5 HP, made in Belgiun, Model BE7RSLH, AND NOW UNDER REBUILT THE CARBURETOR, BASE ON ON IT, PLEASE, HOW i CAN SELECT EXSATLY PARTS FOR THIS 7 hp MOTOR????? do you know some web site where I could get those information? your support and assistance will be highly appreciated
GA_Boater
Welcome aboard, cumana.
Moved your post out of an old thread to one of your own.
What parts do you need?
hardwater fisherman
He has another post going for this motor and he was looking for a carb kit, Also he said it has not run in 15 years so it would need a water pump. I saw one of these super 6.5 for sale near me last year. From what I saw and since read it appears to be a 6hp motor. With different decals and some kind of AC generator.
Bonaventure
Back in the 80's, Evinrude and Johnson marketed a 6.5 HP under a Commercial Motor, designed for Professional Fishermen etc. The Johnson model was a Gold Colour.
I would think you should be able to use a Carburator Kit for a 6 HP or a 7 1/2. Same for water pump.
cumana
Hello GA_Boater how are you, thanks a lot for your answer to my inquire, and regarding to it I would like to inform to this forum, that after surfing in some web site I found the next information related to outboar
Evinrude, Super 6.5 HP, BE7RSLH, is a Evinrude, made in Belgium, 7 HP, rope start, Standard long, Model year 1985.
Please base on this information could you recomend me how to get the next parts:
Carb repair kit.
Thanks a lot for your time and help in this matter
Factory repair kit is 439072 or aftermarket is Sierra 18-7223.---I would take the carburetor apart first to see if it needs a kit.-----Any other trouble shooting done ?-----Replace water pump impeller too.-----Inspect gearcase oil and make sure there is no water in there.
cumana
Hello racerone, a nice to contact you, and thanks a lot for your information regarding to Carb kit, and thanks for your suggestion about maintenance parts to be done I already did it but some problems with idlee RPM, it can not keep low RPM and LOW SPEED needle locks like someting wrong because it move during outboard run, and regarding to it I would like to know where I can Found repair parts information regarding to this Outboard, I will need some carb components parts to complete the rebuilt. I will appreciated so much your information about it Best regards
cumana
Hello racerone, a plased to meet you, thanks a lot for your time to answer my inquire, and regarding to it I would like to inform you that I was locking for 0439072 Carb repair KIt, in Amazon web site, wich is more near from me, and appear some another sustitute number as: 398453, 398452, 391305 & 391937, base on it I would like to know in wich Carb number I need to select Carb repair Kit and Needle slow speed and retainer needle, and if you know anoher web site for it, please let me know, because at that moment when I runned the Out board, It has a some wrong function at high RPM, and some time the Low speed needle move,.
Additionaly I already did the maintenance to Gear Box, Change the Oil and lubricate movements parts, but additionaly I will need a Water pump impeller.
for best understanding attached. some Carb Photos in order hat you can help me to select the fit parts
Very truly yoou
hardwater fisherman
As I already said you can find your parts by looking at 1985 6hp diagrams. The 0391305 kit will work. The retainer should be in the kit, The water pump kit is 0396644. And the slow speed needle is 0432781.
oldboat1
Look for a hollow bolt, threaded on the outside. They vary according to model. The purpose is to compress the needle washers (2 -- usually cord), and "jam" the needle to keep it from spinning loose. The other version is a plastic retainer (no hollow bolt) that fits in the carb housing -- #16 in the diagram: http://ww2.iboats.com/Carburetor/dm/...iew_id.1546158 The object is to hold the needle tight enough to maintain the setting, but not so tight that you cannot adjust it.
cumana
Hello GA_Boater, how are you, we hope fine.
Regarding to your commentary about this thread I can not understand what do yuo means to " Move your post out an old thread", please could you shown me ho to do it, I Unkonow how to do it because I am do not know how to manage some function in this forum.
Thanks a lot for your understanding in this item
Best regrds
Status
