SeaKaye12
- Jul 3, 2005
- 1,108
I just acquired a 5HP Sears Tecumseh/Eska with the magneto ignition (it's a 1970 model
Spark initially was weak sometimes/non existent other times. I replaced the condensor. The points looked new...but I cleaned then a bit. The coil certainly looks OK.....but I need to check that now somehow.
Do coils typically fail? I've never had to replace a coil yet.....I initially doubted that the coil would be bad.....but I guess I might have been wrong.
Can someone walk me through the procedure to test the coil?
Thanks for reading, Chuck
