I searched the forums here and found the issue with my power pack. In the mean time I found a website that shows what you should see on every CDI/ power pack and on which lead you should see it.
1. Find the model number of your CDI/ power pack
2. Go here http://WWW.cdielectronics.com/Products.aspx?Criteria=1A3
3. Find your CDI / power pack.
4. Click the link that says 'install sheet' under the pic of your cdi
5. A PDF comes up that shows each lead and what to expect when testing with a volt meter.
This helped me quit a bit. I hope it helps you too. I've gotten a ton of help here but never had much to contribute as a beginner. I did a search and didn't find this information. If this is a duplicate, I apologize.
