How to test a coil?
sledstew
I have a 4.3 liter and was wondering if there is any way to test a ignition coil.
Reel Poor
Re: How to test a coil?
Yes there is.<br /><br />Year, make, and model please?
sledstew
1988 Lund baron 2100, 4.3 liter v6 /cobra outdrive
Reel Poor
Another question ,does a boat require more fuel in gear than out of gear in nuetral? Im going to check the pressure on my fuel pump and see if thats it, If I remember right I believe it should have 7lbs of pressure.<br /><br />--------------------<br />Jake
What was the results of this test?<br /><br />Jake your problem sounds like a fuel supply problem.
Chris1956
Jake, The classic test for any ignitiion coil is:<br />No continuity between primary winding and coil case<br />No continuity between secondary winding (distributor High Voltage connection) and coil case.<br /><br />Very little resistance (1 ohm) across primary winding<br /><br />More resistance (Dependent on exact coil under test, but not infinite resistance) from plus side of primary winding to secondary winding.
Rhadley
Also check it hot since sometimes a coil will fail only after heating up.
