Putzaroni1
- Oct 20, 2012
- 108
I watched the video from CajunCookOne which was excellent.
Evinrude Gale and Johnson ignition video part 1 of 7 - YouTube
It breaks everything down clearly but I purchased a couple of new coils and decided to test one using the method he demonstrated. I tested the primary winding by using an Ohmmeter from the Red wire to the Black Ground wire and showed continuity. I then tested the secondary winding by going from the Black ground wire to the pin where the spark plug wire will be attached. There is no sign of continuity.
It looks from your video like there should be a slight reading at least. I believe you got a reading of 5. I am getting nothing. Am I doing this test correctly ? This is a brand new coil. Is it just bad or am I doing this wrong ?
