bowman316
- Oct 21, 2008
- 1,822
I have turnbuckles on all of my stays going to the mast. But the turnbuckle is already as tight/short as it will get, and the cables are a little too loose. So as it is, I can't tighten the forestay or mainstay anymore.
I assume I would have to cut the cable, and wind out the turnbuckle, then reattach the now shorter cable to the turnbuckle. But how do i do that? Is there an easy way to put a fitting on the end of a steel cable?
Is it kinda like crimping a fitting onto an electrical wire, like you would to for a car battery terminal?
Or is it so hard, I should just be happy with how tight it is now?
