Re: How to save fuel? cruising speed the only way?
I was thinking about this thread a little more, and if you really look at the title and the OP's question, the answer is more this:
The short answer is: The engine in full tune, the correct prop (and pitch), don't overload the weight in the boat, and run at moderate speeds.
And of the others are right I think weight is probably the factor that can have the most influence, and the one you have some control of. If you absolutely wanted the best fuel economy with a given combination start with the least possible amount of fuel, and nothing in the boat but a throttle jockey. No passengers, tools, liquids, spares, stuff, anchors, fenders, lines, water toys, seats, life jackets, nuttin'. Of course that's neither safe nor practical, but maybe a way to think about trimming unnecessary weight is to reassess what' you need and use on board. And it might be a good way to tell the Admiral that your mother-in-law isn't welcome
And I don't think trim has been mentioned, which is also somewhat about weight distribution. You need to be able to get the bow up a little at cruise too. Obviously important for top speed, but more speed with the same throttle input is an efficiency gain, and can be huge. More than 5 mph is an easy difference between down and up at cruise. That's 15% plus at typical 30 MPH cruise speeds.
