Re: How to rotate mercruiser 3.0 manually
first, i don't know about yours but this is what i did on mine "120".
projecthog gave advise that was helpfull to me.
i way over filled the crankcase so the crank is under thin oil.
use what you want trans fluid whatever, i use/used 30/70% diesel fuel/oil.
i pulled the valve cover and shot a generous amount of blaster using the straw onto the valve stems and all over.
then pulled the plugs and really laid into it with the blaster.
in short oil the heck out of everything you see other than the belts.
i even sprayed the hose clamps, bolts, carb and linkage, starter, everything.
then on the right side of the engine just above the starter there is about a 1" opening.
you can see the teeth on the flywheel and this is were i used a large screwdriver to pry against the teeth.
be very careful and just try to work the flywheel back and forth lightly.
i cut several small pieces of wood to pry against so the screwdriver wasn't resting on metal.
it took me an easy hour or more of just working the teeth back and forth "easily".
at first it looked like i was getting nothing.
then it looked like i was getting something but it was so little i wasn't sure if i was getting anything at all.
finally i got a little more and a little more untill i could get a full revolution.
from that point as don s mentioned i could use the alternator.
well good luck and hope it works for you as it did for me.
to all thank you for your help.
