I have a 1989 90Hp 3 cyl 2 stroke Mariner Outboard - Serial Number of Motor is: OC206555
My oil float sensor in the bottom of my oil tank will not float, which is causing the oil pressure alarm to go off. The engine IS getting oil, and the sensor is working fine.
I have used a small stick to manually raise the float (I do not feel any resistance when raising it), and the alarm stops, but the oil does not seem to keep the float "floating". I can't seem to figure out how to get the float out to see what is wrong with it, or is it built in the tank itself?
Any ideas how to fix this issue?
Again, the engine is getting oil, and the I have diagnosed the problem to be the float inside the oil tank, how to fix this.
Thanks again
K
Thanks again
K
