Re: how to replace a timmer base
First.....get a manual. OEM preferred or get a generic from right here on iboats.<br /><br />What it will tell you is, remove the flywheel. Then remove the four retaining screws that hold the stator on and remove it. Then remove the four clip screw that hold the timer base clips to the timer base and remove the timer base. Basically, thats' what it will say. Easy.
