How to repair a rubber exhaust bellows
manapuaman
I have a 1990 Maxum L-drive 120 Force fish & ski boat that has a small hole in the exhaust bellows. The part is no longer available and I need to know if anyone knows of any rubber repair or urethane sealant that can repair the exhaust bellows.
smokeonthewater
Re: How to repair a rubber exhaust bellows
unless the sound is a problem a small hole in exhaust bellows shouldn't be any cause for concern... the sad part tho is that it's just a matter of time before it is toast and nothing will repair it... I have never personally put hands on an L drive but possibly pics and measurements would help finding an alternative...
3rdtimesthecharm
I wonder if a tire patch would work? Just my .02 worth.
agallant80
I would think it is there for a reason and I bet that small hole will get big fast. Can you retro fit a bellow from Merc or Volvo to it? If not I would go with the tire patch and see if that works. Even if you manage to get a patch to hold the bellow will not hold out for ever. I would hate to have to figure out how to retrofit something to work on it in the middle of boating season. I would rather do it now when I have forced downtime due to the weather.
Texasmark
I agree that the first hole is the first sign of wearout and continuous patching. Find a suitable alternative.
Mark
agallant80
I would measure the length and circumference of the opening then call a drive shaft shop. They would have to have something that would fit. There are many drive shafts and cv joints that use bellows.
Don S
Obviously people replying have no clue what the exhaust bellows on an L-drive is. Item 7 in the picture below, PN F695130-3.
Nordin
Have you tried FranzMarine.com? He has alot of Chrysler/Force parts.
manapuaman
Looks like I may have everyone looking/answering for the wrong part; it is not the exhaust bellows that has a small hole, it is the U-Joint bellows that has a hole in it. Any help or suggestions would be greatly appreciated (part# F695129 for 1990 Maxum L-drive 120 Force)
RogersJetboat454
http://www.boats[DOT]net/parts/detail/merc/M-F695129.html
(Remove the DOT, and add a . in it's place)
Quicksilver by Mercury, Bellows, U-Joint, F695129
Have you talked to these ^^^ two?
jerryjerry05
Still lots of parts available.Franz Marine boats . net Mercury etc.
liljon
they make heat tape for taping furnace plentums,might be worth a try,if it works,post for otherpeople,i would tape the whole way around a few times for good measure,it is a tough thick foil type tape
