how to remove this control arm (BRP concealed)
lajos_
Hi all-
Does anyone know how to remove the control arm on this BRP concealed control unit? I thought this was a #5006561 unit (engine is 2011 ETec 60hp), but mine doesn't have the two screws under the cover, it has a black disc instead. No screws anywhere that I could find (not even on the bottom side of the control arm).
Any help would be appreciated.
Thanks-
Lajos
Grub54891
Is that a screw hole just behind the lever? If not, reach behind the panel ans feel around for any bolts/screws.
lajos_
That hole on the cover is an adjustment screw.
The only bolts I can see behind the unit, are the mounting bolts for the unit. I tried to remove those, but they turn freely. I assume the bolt heads are under the lever cover, but cannot get to those without removing the lever.
