How to remove the cam flollower on the carb
whejdak
I have a 1974 Evinrude 6 hp that I just purchased. In going through a check out, I noticed the cam and and cam follower had worn marks in both. I Bought a new cam and looks easy enough to replace but the follower which is on the carb. is hidden behind the pull rope starter. Do I need to remove that hand starter? There is a link between the follower and the butterfly. Can't see how to remove it.
Grub54891
Them can be a pain to replace, usually you have to remove the carb, which may require you to remove the pull start. Then getting the pull start back on with the proper spring tension is tricky also. Been awhile since I had to do one but I think that's what has to happen. Maby some else will chime in with a better way......
flyingscott
You don't need to remove the pull start. Just take the top bolts out that hold the recoil shaft in place. Then just push the top of the recoil away from the motor just enough to get the carb mounting nut. That should let you get the carb off. You don't want to pull up or push it to far or you will be re-doing the spring.
whejdak
So it looks like the carb has to come off. I was hoping that I could get the follower off without pulling the carb.
kbait
Carb can stay on.. recoil loosened as per 'flyingscott'^ to get to the cam follower pivot bolt. Remove bolt to remove follower.
Good luck!
whejdak
Kbait I believe you are right. Carb should stay on and pull rope just moved aside. I've been looking at it very closely and that should work.
Thanks
