How to remove starter on merc 800 1972???? pics
awood1200
How in the world do you remove the starter from this engine. No help in Seloc manual.
Chris1956
I had a '73 which had the same starter. If I remember correctly, remove the starter cable and ground, remove the bottom bolt, and the starter should move down and pull out of the top bracket.
awood1200
I removed all bolts and nuts. The starter is mounted in what looks like a cast mount top and bottom. This is puzzling.
Faztbullet
Remove the 2 bolts that hold lower bracket to front crancase half, long extension and swivel helps.....
