Re: How to remove seat back.
I know this is a couple of months old but.......the seat back will come off by first removing screws that are at the bottom of the cushion itself, if you move the seat cushion you will see a screw on each side that goes thorough a "figure eight" at the bottom. remove those screws and the seat back will lift straight up off of some clips. then there is the panel that is screwed on....something like 6 screws that you will see after removing the cushion, and 2 screws that go in from the engine compartment side....at least thats how my 2011 202 is, had it off last week. @ ShadowB......Lanyard is exactly what I did too, small cable attached to the lynch pin on the actuator shaft and a keyring loop that barely sticks out from under the hatch at the transom walk thru.......very odd they dont' think of that at the factory.......seat back is not an option on mine if the hatch motor dies, seeing as there are 2 screws holding the panel on from the inside as I stated above..
2011 202 Sundeck Sport 220HP
