How to remove pin in shift linkage in order to change water pump
vasi
How do you remove pins in shift linkage, concerned using a hammer to knock out pin will bend the rod
Chris1956
Normally Mercury motors have a splined slip fit for the shift rod. What HP and year motor do you have?
