[h=2][/h]
Removing lower cowling on my 4hp 2001 model# J4RLSIB The service manual states .... after study of Figure 39, the text says to remove the choke knob from the shaft before removing the lower front cover. this suggests that the choke knob MUST separate from the choke shaft and this should allow the lower front engine cover to come away. How do I make this separation? The part numbers are from the diagram. #42 Part# 336186– KNOB, CHOKE and it must be separated from #38 Part# 326224—SHAFT, CHOKE & FUEL SHUT OFF. Thank you
