afirststep
- Sep 24, 2011
- 11
Gimbal bearing removed using a home made threaded puller. - No problem.
Can only get behind the rubber part of the gimbal bearing seal. - Problem - metal ring on seal will not budge.
A hook type seal remover that hooks inside and levers over the front to pull one side of the bearing out did not work. The gimbal rotated all the way up, the seal puller inserted, and pulled down. The rubber part of the seal just ripped.
A rod type long shaft seal puller that has a notch in the end could only grab rubber. Same result - rubber moves, metal ring on seal still in place.
I can not seem to get behind the metal 'U' shaped ring to remove it, I was thinking of using a long screw driver and damage the outside lip to collapse the metal ring, but figured I might damage the transom surface.
How do I get the gimbal bearing seal out of the circular cup it is in? Keep in mind the bellows are installed...
Humbled, Advance DIYer
