how to remove flywheel hub on 1983 mercury 150
Drivesideways
i rurnt the rings and blew up my pistons in my mercury( i think 1983)150. im tearin it down to polish the cylinders. this is my first time woking on a marine engine period. ive got it down to where i have to unfortunately take off the fly wheel. i did so but the hub doesnt wanna come and i dont like forcing things unless thats all you can do. what do i do?
Laddies
Banned
Re: how to remove flywheel hub on 1983 mercury 150
First you should never disassemble a flywheel sxcept to change the flex plate, never put a puller on the outside flange as it can warp and cause the flex plate to crack. Get the Mercury type puller so you don't damage the hub and it should come off.
Faztbullet
Laddie's is correct you need the tool like below:
Flywheel Puller
201
Pro Marine
Flywheel puller for Mercury outboards. Threads go into flywheel and center screws into it and pushes against the crankshaft to loosen the flywheel.
$59.95
http://www.promarineusa.com
Chris1956
Drive, I pulled the flywheel hub on my inline six with a harmonic balancer puller and teo or three 5/16 fine thread bolts.
On the inline motor it was not necessary to remove the flywheel hub, unless you needed to change the top main bearing. I have not yet taken my Merc V6 apart (knock wood), so I do not know if you need to remove the flywheel hub to overhaul.
Laddies
Banned
Anytime you pull on the outer diameter of the hub you stand a good chance of distorting it. That's not my idea it comes from Mercury Marine.
