On my 1986 Evinrude 9.9 the lower gearcase oil filler screw is now loose, but won't come out. I turned it to change the gearcase oil, and there was a tiny snap, and it now turns around non-stop. I <br />guess either the screw has broken or the case threads have stripped. <br />My immediate problem is how to remove the screw. I can't get a grip on it because it is set flush to the outside of the case. Does anyone have any suggestions?<br /><br />Then, if I can remove the screw, what should I do next? If the case is stripped, can it be rethreaded? I suspect not, since it is cast aluminum, but I'm no expert. Again, any <br />suggestions?<br /><br />Thanks in advance!
