Re: How to properly set idle and fuel mixture on force 120
Straight out of a force manual:
Starting mixture screw is 1 full turn out from lightly seated.
1 With boat tied securely to dock, start motor and run until fully warmed up.
2 Set controls to high-idle neutral position.
3 Turn idle mixture screws slowly open, counterclockwise, until motor loses power and begins to roll due to an over-rich mixture. Note this position
4 Slowly turn screws closed, clockwise, until motor runs smoothly and begins to pick up speed. Continue turning clockwise until motor pops or stalls due to lean mixture. Note this position
5 Set screws halfway between the two positions
I then go 1/8 turn richer just to be safe, rather be rich than lean
