I'm sure this has been asked numerous times but I didn't find it in the forum :facepalm: , Just replaced the impeller and it doesn't seem to want to prime either with muffs or on the trailer sitting at the ramp. I haven't run it more than 60 seconds per attempt or run the RPMs past idle. The new impeller is from the Volvo store and looks to be the same as the one that came out (which appeared to be in good shape). The swap (other than standing on my head to get to the pump) was uneventful.
Just before replacing the impeller, had run the motor with the muffs to flush out the low tox antifreeze and it was dumping water from the exhaust. Now after replacing the impeller there isn't any water coming out with the exhaust. The only thing that changed between flushing the antifreeze and now was replacing the impeller. What am I overlooking or not doing ?
