How to know what is cracked engine block, head or exaust manifold?
Encore985
Hi I'm new here hoping to find an answer how do I find out what's cracked on my 1972 inline 6 cylinder gm motor I took it out for the first time this year for about 45 mins and the motor filled with water till it stalled out no gauges moved everything was normal till she died now the motor is in peices but can't find a crack gaskets where all good and there was only water in the oil non in the pistons and no oil in the water
Re: How to know what is cracked engine block, head or exaust manifold?
Ayuh,.... Welcome Aboard,.... You have to pressurize the coolin' passages with air,....
of course, it'd been Alot easier to do, before ya tore it apart,...
Bt Doctur
what did it do last year?
Where do you live?
Was it winterized properly?
achris
More fish than mountain goat
Water can't get into the oil pan from a cracked manifold, so it's either the block or the head. If the old head gasket is in ok condition, I'd be putting it back on and tightening down the head again, putting the water pump and thermostat housing/water distribution block back on and pressurising it up to find where the crack is....
Chris.......
Encore985
Thx a lot I guess I'll have to it back together to find out and yes I didn't winterize it right
Ayuh,.... Most Machine Shops can find the problem, without wastin' all the gaskets,...
chris650
I have to go with chris and bondo on this one! Btw...if either of you guys get a chance, could you check out the post I left in the restoration section? I trust both of your opinions! Thx. The post is bilge vent.
achris
Wasn't suggesting new gaskets, just that if the old ones are in ok shape, use them. It's just for a pressure test, I'm not suggesting running the engine with them :facepalm: ;)
Done :thumb:.... You know the saying... You wish..etc,etc... ;)
